Gudhi::skeleton_blocker::SkeletonBlockerGeometricDS< GeometryTrait >::Graph_Edge Class Reference
Edge that allows to access to an index. The indices of the edges are used to store heap information in the edge contraction algorithm. More...
#include </home/gailuron/workspace/gudhi/gudhi-devel/build/gudhi.3.5.0/concept/Skeleton_blocker/SkeletonBlockerGeometricDS.h>
Public Member Functions
int & index ()
 Access to the index.
int index ()
- Public Member Functions inherited from Gudhi::skeleton_blocker::SkeletonBlockerDS::Graph_edge
void setId (Root_vertex_handle a, Root_vertex_handle b)
 Allows to modify vertices of the edge.
Root_vertex_handle first () const
 Returns the first vertex of the edge.
Root_vertex_handle second () const
 Returns the second vertex of the edge.
Detailed Description
template<typename GeometryTrait>
class Gudhi::skeleton_blocker::SkeletonBlockerGeometricDS< GeometryTrait >::Graph_Edge
The documentation for this class was generated from the following file:
GUDHI  Version 3.5.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Thu Jan 13 2022 08:34:28 for GUDHI by Doxygen 1.9.2
