Simplex_tree/graph_expansion_with_blocker.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Vincent Rouvreau
* Copyright (C) 2014
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/Simplex_tree.h>
#include <iostream>
using Simplex_handle = Simplex_tree::Simplex_handle;
int main(int argc, char* const argv[]) {
// Construct the Simplex Tree with a 1-skeleton graph example
Simplex_tree simplexTree;
simplexTree.insert_simplex({0, 1}, 0.);
simplexTree.insert_simplex({0, 2}, 1.);
simplexTree.insert_simplex({0, 3}, 2.);
simplexTree.insert_simplex({1, 2}, 3.);
simplexTree.insert_simplex({1, 3}, 4.);
simplexTree.insert_simplex({2, 3}, 5.);
simplexTree.insert_simplex({2, 4}, 6.);
simplexTree.insert_simplex({3, 6}, 7.);
simplexTree.insert_simplex({4, 5}, 8.);
simplexTree.insert_simplex({4, 6}, 9.);
simplexTree.insert_simplex({5, 6}, 10.);
simplexTree.insert_simplex({6}, 10.);
simplexTree.expansion_with_blockers(3, [&](Simplex_handle sh) {
bool result = false;
std::cout << "Blocker on [";
// User can loop on the vertices from the given simplex_handle i.e.
for (auto vertex : simplexTree.simplex_vertex_range(sh)) {
// We block the expansion, if the vertex '6' is in the given list of vertices
if (vertex == 6) result = true;
std::cout << vertex << ", ";
std::cout << "] ( " << simplexTree.filtration(sh);
// User can re-assign a new filtration value directly in the blocker (default is the maximal value of boudaries)
simplexTree.assign_filtration(sh, simplexTree.filtration(sh) + 1.);
std::cout << " + 1. ) = " << result << std::endl;
return result;
std::cout << "********************************************************************\n";
std::cout << "* The complex contains " << simplexTree.num_simplices() << " simplices";
std::cout << " - dimension " << simplexTree.dimension() << "\n";
std::cout << "* Iterator on Simplices in the filtration, with [filtration value]:\n";
for (auto f_simplex : simplexTree.filtration_simplex_range()) {
std::cout << " "
<< "[" << simplexTree.filtration(f_simplex) << "] ";
for (auto vertex : simplexTree.simplex_vertex_range(f_simplex)) std::cout << "(" << vertex << ")";
std::cout << std::endl;
return 0;
GUDHI  Version 2.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Wed Jan 31 2018 09:40:55 for GUDHI by Doxygen 1.8.11
