Persistence_representations/persistence_intervals/compute_number_of_dominant_intervals.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Pawel Dlotko
* Copyright (C) 2016 INRIA (France)
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/Persistence_intervals.h>
#include <iostream>
#include <limits>
#include <vector>
#include <utility>
int main(int argc, char** argv) {
std::cout << "This program compute the dominant intervals. A number of intervals to be displayed is a parameter of "
"this program. \n";
if (argc != 4) {
std::cout << "To run this program, please provide the name of a file with persistence diagram, dimension of "
"intervals that should be taken into account (if your file contains only persistence pairs in a "
"single dimension, set it up to -1) and number of dominant intervals you would like to get \n";
return 1;
int dim = atoi(argv[2]);
unsigned dimension = std::numeric_limits<unsigned>::max();
if (dim >= 0) {
dimension = (unsigned)dim;
Persistence_intervals p(argv[1], dimension);
std::vector<std::pair<double, double> > dominant_intervals = p.dominant_intervals(atoi(argv[3]));
std::cout << "Here are the dominant intervals : " << std::endl;
for (size_t i = 0; i != dominant_intervals.size(); ++i) {
std::cout << " " << dominant_intervals[i].first << "," << dominant_intervals[i].second << " " << std::endl;
return 0;
GUDHI  Version 2.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Wed Jan 31 2018 09:40:55 for GUDHI by Doxygen 1.8.11
