Bitmap_cubical_complex/periodic_cubical_complex_persistence.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Pawel Dlotko
* Copyright (C) 2015 INRIA Saclay (France)
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/Bitmap_cubical_complex.h>
#include <gudhi/Bitmap_cubical_complex_periodic_boundary_conditions_base.h>
#include <gudhi/Persistent_cohomology.h>
// standard stuff
#include <iostream>
#include <sstream>
#include <vector>
#include <string>
int main(int argc, char** argv) {
std::cout
<< "This program computes persistent homology, by using "
<< "Bitmap_cubical_complex_periodic_boundary_conditions class, of cubical complexes provided in text files in "
<< "Perseus style (the only numbered in the first line is a dimension D of a bitmap. In the lines I between 2 "
<< "and D+1 there are numbers of top dimensional cells in the direction I. Let N denote product of the numbers "
<< "in the lines between 2 and D. In the lines D+2 to D+2+N there are filtrations of top dimensional cells. We "
<< "assume that the cells are in the lexicographical order. See CubicalOneSphere.txt or CubicalTwoSphere.txt for"
<< " example.\n"
<< std::endl;
if (argc != 2) {
std::cerr << "Wrong number of parameters. Please provide the name of a file with a Perseus style bitmap at "
<< "the input. The program will now terminate.\n";
return 1;
Bitmap_cubical_complex b(argv[1]);
// Compute the persistence diagram of the complex
Persistent_cohomology pcoh(b, true);
int p = 11;
double min_persistence = 0;
pcoh.init_coefficients(p); // initializes the coefficient field for homology
pcoh.compute_persistent_cohomology(min_persistence);
std::string output_file_name(argv[1]);
output_file_name += "_persistence";
std::size_t last_in_path = output_file_name.find_last_of("/\\");
if (last_in_path != std::string::npos) {
output_file_name = output_file_name.substr(last_in_path + 1);
std::ofstream out(output_file_name.c_str());
pcoh.output_diagram(out);
out.close();
std::cout << "Result in file: " << output_file_name << "\n";
return 0;
GUDHI  Version 2.1.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : GPL v3 Generated on Wed Jan 31 2018 09:40:54 for GUDHI by Doxygen 1.8.11
