Simplex_tree/mini_simplex_tree.cpp
/* This file is part of the Gudhi Library. The Gudhi library
* (Geometric Understanding in Higher Dimensions) is a generic C++
* library for computational topology.
* Author(s): Marc Glisse
* Copyright (C) 2015 INRIA Saclay - Ile-de-France (France)
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <initializer_list>
// Not doing persistence, so we don't need those
static const bool store_key = false;
static const bool store_filtration = false;
// I have few vertices
typedef short Vertex_handle;
// Dictionary should be private, but for now this is the easiest way.
static_assert(sizeof(ST::Dictionary::value_type) < sizeof(Gudhi::Simplex_tree<>::Dictionary::value_type),
"Not storing the filtration and key should save some space");
int main() {
ST st;
/* Complex to build. */
/* 1 */
/* o */
/* /X\ */
/* o---o---o */
/* 2 0 3 */
auto triangle012 = {0, 1, 2};
auto edge03 = {0, 3};
st.insert_simplex_and_subfaces(triangle012);
st.insert_simplex_and_subfaces(edge03);
// FIXME: Remove this line
st.set_dimension(2);
auto edge02 = {0, 2};
ST::Simplex_handle e = st.find(edge02);
// We are not using filtrations so everything has value 0
assert(st.filtration(e) == 0);
for (ST::Simplex_handle t : st.cofaces_simplex_range(e, 1)) {
// Only coface is 012
for (ST::Vertex_handle v : st.simplex_vertex_range(t)) // v in { 0, 1, 2 }
std::cout << v;
std::cout << '\n';
GUDHI  Version 2.0.1  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. Generated on Mon Oct 2 2017 10:20:49 for GUDHI by doxygen 1.8.11
