All Classes Functions Variables Typedefs Friends Groups Pages
SimplexTreeOptions.h
1  /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): Marc Glisse
6  *
7  * Copyright (C) 2015 INRIA Saclay - Ile-de-France (France)
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22
37  static const bool store_key;
39  static const bool store_filtration;
41  static constexpr bool contiguous_vertices;
42 };
43
IndexingTag Indexing_tag
Forced for now.
Definition: SimplexTreeOptions.h:29
VertexHandle Vertex_handle
Must be a signed integer type. It admits a total order <.
Definition: SimplexTreeOptions.h:31
Concept describing an indexing scheme (see FilteredComplex) for applying continuous maps to a cell co...
Definition: IndexingTag.h:30
If true, the list of vertices present in the complex must always be 0, ..., num_vertices-1, without any hole.
Definition: SimplexTreeOptions.h:41
Key type used as simplex identifier.
Definition: SimplexKey.h:27
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:32
FiltrationValue Filtration_value
Must be comparable with operator<.
Definition: SimplexTreeOptions.h:33
Concept of the template parameter for the class Gudhi::Simplex_tree<SimplexTreeOptions>.
Definition: SimplexTreeOptions.h:27
SimplexKey Simplex_key
Definition: SimplexTreeOptions.h:35
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:27
If true, each simplex has extra storage for one Filtration_value, and this value is propagated by ope...
Definition: SimplexTreeOptions.h:39
If true, each simplex has extra storage for one Simplex_key. Necessary for Persistent_cohomology.
Definition: SimplexTreeOptions.h:37
GUDHI  Version 1.3.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding. Generated on Fri Apr 15 2016 17:36:21 for GUDHI by doxygen 1.8.6
