#include <gudhi/graph_simplicial_complex.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <utility>
#include <vector>
using namespace Gudhi;
typedef std::vector< Vertex_handle > typeVectorVertex;
typedef std::pair< Simplex_tree<>::Simplex_handle, bool > typePairSimplexBool;
int main(int argc, char * const argv[]) {
const Filtration_value FIRST_FILTRATION_VALUE = 0.1;
const Filtration_value SECOND_FILTRATION_VALUE = 0.2;
const Filtration_value THIRD_FILTRATION_VALUE = 0.3;
const Filtration_value FOURTH_FILTRATION_VALUE = 0.4;
std::cout << "********************************************************************" << std::endl;
std::cout << "EXAMPLE OF SIMPLE INSERTION" << std::endl;
std::cout << " * INSERT 0" << std::endl;
typeVectorVertex firstSimplexVector = { 0 };
typePairSimplexBool returnValue =
simplexTree.
insert_simplex(firstSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
if (returnValue.second == true) {
std::cout << " + 0 INSERTED" << std::endl;
} else {
std::cout << " - 0 NOT INSERTED" << std::endl;
std::cout << " * INSERT 1" << std::endl;
typeVectorVertex secondSimplexVector = { 1 };
returnValue =
simplexTree.
insert_simplex(secondSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::cout << " + 1 INSERTED" << std::endl;
} else {
std::cout << " - 1 NOT INSERTED" << std::endl;
std::cout << " * INSERT (0,1)" << std::endl;
typeVectorVertex thirdSimplexVector = { 0, 1 };
returnValue =
simplexTree.
insert_simplex(thirdSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (0,1) INSERTED" << std::endl;
} else {
std::cout << " - (0,1) NOT INSERTED" << std::endl;
std::cout << " * INSERT 2" << std::endl;
typeVectorVertex fourthSimplexVector = { 2 };
returnValue =
simplexTree.
insert_simplex(fourthSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::cout << " + 2 INSERTED" << std::endl;
} else {
std::cout << " - 2 NOT INSERTED" << std::endl;
std::cout << " * INSERT (2,0)" << std::endl;
typeVectorVertex fifthSimplexVector = { 2, 0 };
returnValue =
simplexTree.
insert_simplex(fifthSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (2,0) INSERTED" << std::endl;
} else {
std::cout << " - (2,0) NOT INSERTED" << std::endl;
std::cout << " * INSERT (2,1)" << std::endl;
typeVectorVertex sixthSimplexVector = { 2, 1 };
returnValue =
simplexTree.
insert_simplex(sixthSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (2,1) INSERTED" << std::endl;
} else {
std::cout << " - (2,1) NOT INSERTED" << std::endl;
std::cout << " * INSERT (2,1,0)" << std::endl;
typeVectorVertex seventhSimplexVector = { 2, 1, 0 };
returnValue =
simplexTree.
insert_simplex(seventhSimplexVector, Filtration_value(THIRD_FILTRATION_VALUE));
std::cout << " + (2,1,0) INSERTED" << std::endl;
} else {
std::cout << " - (2,1,0) NOT INSERTED" << std::endl;
std::cout << " * INSERT 3" << std::endl;
typeVectorVertex eighthSimplexVector = { 3 };
returnValue =
simplexTree.
insert_simplex(eighthSimplexVector, Filtration_value(FIRST_FILTRATION_VALUE));
std::cout << " + 3 INSERTED" << std::endl;
} else {
std::cout << " - 3 NOT INSERTED" << std::endl;
std::cout << " * INSERT (3,0)" << std::endl;
typeVectorVertex ninethSimplexVector = { 3, 0 };
returnValue =
simplexTree.
insert_simplex(ninethSimplexVector, Filtration_value(SECOND_FILTRATION_VALUE));
std::cout << " + (3,0) INSERTED" << std::endl;
} else {
std::cout << " - (3,0) NOT INSERTED" << std::endl;
std::cout << " * INSERT 0 (already inserted)" << std::endl;
typeVectorVertex tenthSimplexVector = { 0 };
returnValue = simplexTree.
insert_simplex(tenthSimplexVector, Filtration_value(FOURTH_FILTRATION_VALUE));
} else {
std::cout << " * INSERT (2,1,0) (already inserted)" << std::endl;
typeVectorVertex eleventhSimplexVector = { 2, 1, 0 };
returnValue =
simplexTree.
insert_simplex(eleventhSimplexVector, Filtration_value(FOURTH_FILTRATION_VALUE));
} else {
std::cout << "********************************************************************\n";
std::cout <<
"* The complex contains " << simplexTree.
num_simplices() <<
" simplices\n";
std::cout <<
" - dimension " << simplexTree.
dimension() <<
" - filtration " << simplexTree.
filtration() <<
"\n";
std::cout << "* Iterator on Simplices in the filtration, with [filtration value]:\n";
std::cout <<
"[" << simplexTree.
filtration(f_simplex) <<
std::cout << static_cast<int>(vertex) << " ";
std::cout << std::endl;
std::cout << "**************IS THE SIMPLEX {1} IN THE SIMPLEX TREE ?\n";
std::cout << "***+ YES IT IS!\n";
else
std::cout << "***- NO IT ISN'T\n";
typeVectorVertex unknownSimplexVector = { 15 };
simplexFound = simplexTree.
find(unknownSimplexVector);
std::cout << "**************IS THE SIMPLEX {15} IN THE SIMPLEX TREE ?\n";
else
find(fifthSimplexVector);
std::cout << "**************IS THE SIMPLEX {2,0} IN THE SIMPLEX TREE ?\n";
else
typeVectorVertex otherSimplexVector = { 1, 15 };
find(otherSimplexVector);
std::cout << "**************IS THE SIMPLEX {15,1} IN THE SIMPLEX TREE ?\n";
else
typeVectorVertex invSimplexVector = { 1, 2, 0 };
find(invSimplexVector);
std::cout << "**************IS THE SIMPLEX {1,2,0} IN THE SIMPLEX TREE ?\n";
else
return 0;
