#include <gudhi/reader_utils.h>
#include <gudhi/graph_simplicial_complex.h>
#include <gudhi/distance_functions.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/Persistent_cohomology/Multi_field.h>
#include <gudhi/Hasse_complex.h>
#include <chrono>
#include <string>
#include <vector>
using namespace Gudhi;
using namespace Gudhi::persistent_cohomology;
template< typename FilteredComplex>
, int p);
, int p
, int q);
int main(int argc, char * argv[]) {
std::chrono::time_point<std::chrono::system_clock> start, end;
int elapsed_sec;
std::string filepoints = "../../../data/points/Kl.txt";
Filtration_value threshold = 0.27;
int dim_max = 3;
int p = 2;
int q = 1223;
typedef std::vector<double> Point_t;
std::vector< Point_t > points;
read_points(filepoints, points);
start = std::chrono::system_clock::now();
Graph_t prox_graph = compute_proximity_graph(points, threshold
, euclidean_distance<Point_t>);
end = std::chrono::system_clock::now();
elapsed_sec = std::chrono::duration_cast<std::chrono::milliseconds>(end - start).count();
std::cout << "Compute Rips graph in " << elapsed_sec << " ms.\n";
std::cout << "Compute Rips complex in " << elapsed_sec << " ms.\n";
std::cout <<
" - dimension = " << st.
dimension() << std::endl;
std::cout <<
" - number of simplices = " << st.
num_simplices() << std::endl;
std::cout << "Order the simplices of the filtration in " << elapsed_sec << " ms.\n";
int count = 0;
std::cout << "Copied the keys inside the simplices in " << elapsed_sec << " ms.\n";
Hasse_complex<> hcpx(st);
std::cout << "Convert the simplex tree into a Hasse diagram in " << elapsed_sec << " ms.\n";
std::cout << "Timings when using a simplex tree: \n";
timing_persistence(st, p);
timing_persistence(st, q);
timing_persistence(st, p, q);
std::cout << "Timings when using a Hasse complex: \n";
timing_persistence(hcpx, p);
timing_persistence(hcpx, q);
timing_persistence(hcpx, p, q);
std::cout << "Running the complex destructors in " << elapsed_sec << " ms.\n";
return 0;
void
, int p) {
int elapsed_sec;
std::cout << " Initialize pcoh in " << elapsed_sec << " ms.\n";
pcoh.init_coefficients(p);
std::cout << " Initialize the coefficient field in " << elapsed_sec << " ms.\n";
pcoh.compute_persistent_cohomology(INFINITY);
std::cout << " Compute persistent homology in Z/" << p << "Z in " << elapsed_sec << " ms.\n";
std::cout << " Run the persistence destructors in " << elapsed_sec << " ms.\n";
void
, int p
, int q) {
int elapsed_sec;
pcoh.init_coefficients(p, q);
std::cout << " Compute multi-field persistent homology in all coefficient fields Z/pZ "
<< "with p in [" << p << ";" << q << "] in " << elapsed_sec << " ms.\n";
