unspecified Boundary_simplex_iterator
Iterator on the simplices belonging to the boundary of a simplex.
Definition: FilteredComplex.h:80
unspecified Simplex_key
Key associated to each simplex.
Definition: FilteredComplex.h:35
void assign_key(Simplex_handle sh, Simplex_key key)
Assign a key to a simplex.
Simplex_key null_key()
Returns a key that is different from the keys associated to the simplices.
Simplex_key key(Simplex_handle sh)
Returns the key associated to a simplex.
unspecified Indexing_tag
Specifies the nature of the indexing scheme.
Definition: FilteredComplex.h:44
unspecified Filtration_simplex_iterator
Iterator over all simplices of the complex in the order of the indexing scheme.
Definition: FilteredComplex.h:106
Simplex_handle null_simplex()
unspecified Boundary_simplex_range
Range giving access to the simplices in the boundary of a simplex.
Definition: FilteredComplex.h:86
Filtration_simplex_range filtration_simplex_range()
Returns a range over the simplices of the complex in the order of the filtration. ...
size_t num_simplices()
Returns the number of simplices in the complex.
unspecified Simplex_handle
Definition: FilteredComplex.h:31
unspecified Filtration_simplex_range
Range over the simplices of the complex in the order of the filtration.
Definition: FilteredComplex.h:111
Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
The concept FilteredComplex describes the requirements for a type to implement a filtered cell comple...
Definition: FilteredComplex.h:28
unspecified Filtration_value
Type for the value of the filtration function.
Definition: FilteredComplex.h:39
Simplex_handle simplex(Simplex_key idx)
Returns the simplex that has index idx in the filtration.
Boundary_simplex_range boundary_simplex_range(Simplex_handle sh)
Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimens...
