#include <gudhi/reader_utils.h>
#include <gudhi/Bitmap_cubical_complex.h>
#include <gudhi/Persistent_cohomology.h>
#include <iostream>
#include <sstream>
#include <vector>
int main(int argc, char** argv) {
std::cout << "This program computes persistent homology, by using bitmap_cubical_complex class, of cubical " <<
"complexes provided in text files in Perseus style (the only numbered in the first line is a dimension D of a" <<
"bitmap. In the lines I between 2 and D+1 there are numbers of top dimensional cells in the direction I. Let " <<
"N denote product of the numbers in the lines between 2 and D. In the lines D+2 to D+2+N there are " <<
"filtrations of top dimensional cells. We assume that the cells are in the lexicographical order. See " <<
"CubicalOneSphere.txt or CubicalTwoSphere.txt for example.\n" << std::endl;
int p = 2;
double min_persistence = 0;
if (argc != 2) {
std::cerr << "Wrong number of parameters. Please provide the name of a file with a Perseus style bitmap at " <<
"the input. The program will now terminate.\n";
return 1;
Bitmap_cubical_complex b(argv[1]);
Persistent_cohomology pcoh(b);
pcoh.init_coefficients(p);
pcoh.compute_persistent_cohomology(min_persistence);
std::stringstream ss;
ss << argv[1] << "_persistence";
std::ofstream out(ss.str().c_str());
pcoh.output_diagram(out);
out.close();
std::cout << "Result in file: " << ss.str().c_str() << "\n";
return 0;
