Gudhi  1.2.0
 All Classes Functions Variables Typedefs Friends Groups Pages
Skeleton_blocker_complex_visitor.h
1 /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): David Salinas
6  *
7  * Copyright (C) 2014 INRIA Sophia Antipolis-Mediterranee (France)
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22 #ifndef SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
23 #define SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
24
25 #include <gudhi/Skeleton_blocker/Skeleton_blocker_simplex.h>
26
27 namespace Gudhi {
28
29 namespace skbl {
30 // todo rajouter les const
31
36 template<typename Vertex_handle>
38  public:
40
41  virtual void on_add_vertex(Vertex_handle) = 0;
42  virtual void on_remove_vertex(Vertex_handle) = 0;
43
44  virtual void on_add_edge(Vertex_handle a, Vertex_handle b) = 0;
45  virtual void on_remove_edge(Vertex_handle a, Vertex_handle b) = 0;
46
51  virtual void on_changed_edge(Vertex_handle a, Vertex_handle b) = 0;
52
61  virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b,
62  Vertex_handle x) = 0;
63  virtual void on_add_blocker(
65  virtual void on_delete_blocker(
67 };
68
74 template<typename Vertex_handle>
76  Vertex_handle> {
77  public:
78  void on_add_vertex(Vertex_handle) {
79  }
80  void on_remove_vertex(Vertex_handle) {
81  }
82  void on_add_edge(Vertex_handle a, Vertex_handle b) {
83  }
84  void on_remove_edge(Vertex_handle a, Vertex_handle b) {
85  }
86  void on_changed_edge(Vertex_handle a, Vertex_handle b) {
87  }
88  void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x) {
89  }
90  void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>&) {
91  }
92  void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>*) {
93  }
94 };
95
101 template<typename Vertex_handle>
103  Vertex_handle> {
104  public:
105  void on_add_vertex(Vertex_handle v) {
106  std::cerr << "on_add_vertex:" << v << std::endl;
107  }
108  void on_remove_vertex(Vertex_handle v) {
109  std::cerr << "on_remove_vertex:" << v << std::endl;
110  }
111  void on_add_edge(Vertex_handle a, Vertex_handle b) {
112  std::cerr << "on_add_edge:" << a << "," << b << std::endl;
113  }
114  void on_remove_edge(Vertex_handle a, Vertex_handle b) {
115  std::cerr << "on_remove_edge:" << a << "," << b << std::endl;
116  }
117  void on_changed_edge(Vertex_handle a, Vertex_handle b) {
118  std::cerr << "on_changed_edge:" << a << "," << b << std::endl;
119  }
120  void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x) {
121  std::cerr << "on_swaped_edge:" << a << "," << b << "," << x << std::endl;
122  }
123  void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>& b) {
124  std::cerr << "on_add_blocker:" << b << std::endl;
125  }
126  void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>* b) {
127  std::cerr << "on_delete_blocker:" << b << std::endl;
128  }
129 };
130
131 } // namespace skbl
132
133 } // namespace Gudhi
134
135 #endif // SKELETON_BLOCKER_SKELETON_BLOCKER_COMPLEX_VISITOR_H_
virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)=0
Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already pre...
Called when an edge changes, during the contraction of an edge.
Definition: Skeleton_blocker_complex_visitor.h:86
A visitor that prints the visit information.
Definition: Skeleton_blocker_complex_visitor.h:102
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:75
Definition: Skeleton_blocker_complex_visitor.h:88
virtual void on_changed_edge(Vertex_handle a, Vertex_handle b)=0
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:50
Interface for a visitor of a simplicial complex.
Definition: Skeleton_blocker_complex_visitor.h:37
Definition: Skeleton_blocker_complex_visitor.h:120
Definition: Skeleton_blocker_complex_visitor.h:117
