23 #ifndef SIMPLEX_TREE_H_
24 #define SIMPLEX_TREE_H_
26 #include <gudhi/Simplex_tree/Simplex_tree_node_explicit_storage.h>
27 #include <gudhi/Simplex_tree/Simplex_tree_siblings.h>
28 #include <gudhi/Simplex_tree/Simplex_tree_iterators.h>
29 #include <gudhi/Simplex_tree/indexing_tag.h>
31 #include <gudhi/reader_utils.h>
32 #include <gudhi/graph_simplicial_complex.h>
34 #include <boost/container/flat_map.hpp>
35 #include <boost/iterator/transform_iterator.hpp>
36 #include <boost/graph/adjacency_list.hpp>
80 struct Simplex_tree_options_full_featured {
82 typedef linear_indexing_tag Indexing_tag;
83 typedef int Vertex_handle;
84 typedef double Filtration_value;
85 typedef int Simplex_key;
86 static const bool store_key =
true;
87 static const bool store_filtration =
true;
102 template<
typename SimplexTreeOptions = Simplex_tree_options_full_featured>
121 typedef Simplex_tree_node_explicit_storage<Simplex_tree> Node;
126 typedef typename boost::container::flat_map<Vertex_handle, Node> Dictionary;
130 typedef Simplex_tree_siblings<Simplex_tree, Dictionary> Siblings;
132 struct Key_simplex_base_real {
133 Key_simplex_base_real() : key_(-1) {}
139 struct Key_simplex_base_dummy {
140 Key_simplex_base_dummy() {}
144 typedef typename std::conditional<Options::store_key, Key_simplex_base_real, Key_simplex_base_dummy>::type Key_simplex_base;
146 struct Filtration_simplex_base_real {
147 Filtration_simplex_base_real() : filt_(0) {}
148 void assign_filtration(Filtration_value f) { filt_ = f; }
149 Filtration_value
filtration()
const {
return filt_; }
151 Filtration_value filt_;
153 struct Filtration_simplex_base_dummy {
154 Filtration_simplex_base_dummy() {}
155 void assign_filtration(Filtration_value f) { assert(f == 0); }
156 Filtration_value
filtration()
const {
return 0; }
159 Filtration_simplex_base_dummy>::type Filtration_simplex_base;
167 typedef typename Dictionary::iterator Dictionary_it;
168 typedef typename Dictionary_it::value_type Dit_value_t;
170 struct return_first {
234 boost::make_transform_iterator(root_.members_.begin(), return_first()),
235 boost::make_transform_iterator(root_.members_.end(), return_first()));
278 if (filtration_vect_.empty()) {
281 return filtration_vect_;
323 root_(nullptr, null_vertex_),
329 : null_vertex_(simplex_source.null_vertex_),
330 threshold_(simplex_source.threshold_),
332 dimension_(simplex_source.dimension_) {
333 auto root_source = simplex_source.root_;
334 auto memb_source = root_source.members();
335 root_ = Siblings(
nullptr, null_vertex_, memb_source);
340 void rec_copy(Siblings *sib, Siblings *sib_source) {
341 for (
auto sh = sib->members().begin(), sh_source = sib_source->members().begin();
342 sh != sib->members().end(); ++sh, ++sh_source) {
344 Siblings * newsib =
new Siblings(sib, sh_source->first);
345 newsib->members_.reserve(sh_source->second.children()->members().size());
346 for (
auto & child : sh_source->second.children()->members())
347 newsib->members_.emplace_hint(newsib->members_.end(), child.first, Node(sib, child.second.filtration()));
348 rec_copy(newsib, sh_source->second.children());
349 sh->second.assign_children(newsib);
356 : null_vertex_(std::move(old.null_vertex_)),
357 threshold_(std::move(old.threshold_)),
358 root_(std::move(old.root_)),
359 filtration_vect_(std::move(old.filtration_vect_)),
360 dimension_(std::move(old.dimension_)) {
363 old.root_ = Siblings(
nullptr, null_vertex_);
368 for (
auto sh = root_.members().begin(); sh != root_.members().end(); ++sh) {
370 rec_delete(sh->second.children());
377 void rec_delete(Siblings * sib) {
378 for (
auto sh = sib->members().begin(); sh != sib->members().end(); ++sh) {
380 rec_delete(sh->second.children());
389 if ((null_vertex_ != st2.null_vertex_) ||
390 (threshold_ != st2.threshold_) ||
391 (dimension_ != st2.dimension_))
393 return rec_equal(&root_, &st2.root_);
398 return (!(*
this == st2));
403 bool rec_equal(Siblings* s1, Siblings* s2) {
404 if (s1->members().size() != s2->members().size())
406 for (
auto sh1 = s1->members().begin(), sh2 = s2->members().begin();
407 (sh1 != s1->members().end() && sh2 != s2->members().end()); ++sh1, ++sh2) {
408 if (sh1->first != sh2->first || sh1->second.filtration() != sh2->second.filtration())
414 if (!rec_equal(sh1->second.children(), sh2->second.children()))
427 return sh->second.key();
436 return filtration_vect_[
key];
446 return sh->second.filtration();
462 return Dictionary_it(
nullptr);
479 return root_.members_.size();
491 auto sib_begin = sib->members().begin();
492 auto sib_end = sib->members().end();
493 size_t simplices_number = sib_end - sib_begin;
494 for (
auto sh = sib_begin; sh != sib_end; ++sh) {
499 return simplices_number;
509 while (curr_sib !=
nullptr) {
511 curr_sib = curr_sib->oncles();
524 return (sh->second.children()->parent() == sh->first);
534 template<
class InputVertexRange>
536 auto first = std::begin(s);
537 auto last = std::end(s);
543 std::vector<Vertex_handle> copy(first, last);
544 std::sort(std::begin(copy), std::end(copy));
545 return find_simplex(copy);
551 Siblings * tmp_sib = &root_;
552 Dictionary_it tmp_dit;
553 Vertex_handle last = simplex.back();
554 for (
auto v : simplex) {
555 tmp_dit = tmp_sib->members_.find(v);
556 if (tmp_dit == tmp_sib->members_.end()) {
562 tmp_sib = tmp_dit->second.children();
570 return root_.members_.begin() + v;
577 std::pair<Simplex_handle, bool> insert_vertex_vector(
const std::vector<Vertex_handle>& simplex,
579 Siblings * curr_sib = &root_;
580 std::pair<Simplex_handle, bool> res_insert;
581 auto vi = simplex.begin();
582 for (; vi != simplex.end() - 1; ++vi) {
583 res_insert = curr_sib->members_.emplace(*vi, Node(curr_sib, filtration));
585 res_insert.first->second.assign_children(
new Siblings(curr_sib, *vi));
587 curr_sib = res_insert.first->second.children();
589 res_insert = curr_sib->members_.emplace(*vi, Node(curr_sib, filtration));
590 if (!res_insert.second) {
592 if (res_insert.first->second.filtration() >
filtration) {
594 res_insert.first->second.assign_filtration(filtration);
598 return std::pair<Simplex_handle, bool>(
null_simplex(),
false);
628 template<
631 auto first = std::begin(simplex);
632 auto last = std::end(simplex);
635 return std::pair<Simplex_handle, bool>(
null_simplex(),
true);
638 std::vector<Vertex_handle> copy(first, last);
639 std::sort(std::begin(copy), std::end(copy));
640 return insert_vertex_vector(copy, filtration);
657 template<
660 auto first = std::begin(Nsimplex);
661 auto last = std::end(Nsimplex);
664 return std::pair<Simplex_handle, bool>(
null_simplex(),
true);
667 std::vector<Vertex_handle> copy(first, last);
668 std::sort(std::begin(copy), std::end(copy));
670 std::vector<std::vector<Vertex_handle>> to_be_inserted;
671 std::vector<std::vector<Vertex_handle>> to_be_propagated;
672 return rec_insert_simplex_and_subfaces(copy, to_be_inserted, to_be_propagated, filtration);
676 std::pair<Simplex_handle, bool> rec_insert_simplex_and_subfaces(std::vector<Vertex_handle>& the_simplex,
677 std::vector<std::vector<Vertex_handle>>& to_be_inserted,
678 std::vector<std::vector<Vertex_handle>>& to_be_propagated,
679 Filtration_value filtration = 0.0) {
680 std::pair<Simplex_handle, bool> insert_result;
681 if (the_simplex.size() > 1) {
683 Vertex_handle last_vertex = the_simplex.back();
684 the_simplex.pop_back();
686 insert_result = rec_insert_simplex_and_subfaces(the_simplex, to_be_inserted, to_be_propagated, filtration);
689 to_be_inserted.insert(to_be_inserted.begin(), to_be_propagated.begin(), to_be_propagated.end());
690 to_be_propagated = to_be_inserted;
693 for (
auto& simplex_tbi : to_be_inserted) {
694 simplex_tbi.push_back(last_vertex);
696 std::vector<Vertex_handle> last_simplex(1, last_vertex);
697 to_be_inserted.insert(to_be_inserted.begin(), last_simplex);
705 for (
706 insert_result = insert_vertex_vector(simplex_tbi, filtration);
708 }
else if (the_simplex.size() == 1) {
710 if ((to_be_inserted.size() != 0) || (to_be_propagated.size() != 0)) {
711 std::cerr <<
"Simplex_tree::rec_insert_simplex_and_subfaces - Error vector not empty" << std::endl;
714 std::vector<Vertex_handle> first_simplex(1, the_simplex.back());
716 to_be_inserted.push_back(first_simplex);
718 insert_result = insert_vertex_vector(first_simplex, filtration);
720 std::cerr <<
"Simplex_tree::rec_insert_simplex_and_subfaces - Recursivity error" << std::endl;
723 return insert_result;
730 sh->second.assign_key(key);
739 return { find_vertex(sh->first), find_vertex(
self_siblings(sh)->parent()) };
744 if (sh->second.children()->parent() == sh->first)
745 return sh->second.children()->oncles();
747 return sh->second.children();
777 filtration_vect_.clear();
780 filtration_vect_.push_back(sh);
791 std::stable_sort(filtration_vect_.begin(), filtration_vect_.end(),
792 is_before_in_filtration(
this));
808 void rec_coface(std::vector<Vertex_handle> &vertices, Siblings *curr_sib,
int curr_nbVertices,
809 std::vector<Simplex_handle>& cofaces,
bool star,
int nbVertices) {
810 if (!(star || curr_nbVertices <= nbVertices))
812 for (
Simplex_handle simplex = curr_sib->members().begin(); simplex != curr_sib->members().end(); ++
simplex) {
813 if (vertices.empty()) {
818 bool addCoface = (star || curr_nbVertices == nbVertices);
820 cofaces.push_back(simplex);
822 rec_coface(vertices, simplex->second.children(), curr_nbVertices + 1, cofaces, star, nbVertices);
824 if (simplex->first == vertices.back()) {
826 bool equalDim = (star || curr_nbVertices == nbVertices);
827 bool addCoface = vertices.size() == 1 && equalDim;
829 cofaces.push_back(simplex);
832 Vertex_handle tmp = vertices.back();
834 rec_coface(vertices, simplex->second.children(), curr_nbVertices + 1, cofaces, star, nbVertices);
835 vertices.push_back(tmp);
837 }
else if (simplex->first > vertices.back()) {
842 rec_coface(vertices, simplex->second.children(), curr_nbVertices + 1, cofaces, star, nbVertices);
868 assert(codimension >= 0);
870 std::vector<Vertex_handle> copy(rg.begin(), rg.end());
871 if (codimension + static_cast<int>(copy.size()) > dimension_ + 1 ||
872 (codimension == 0 && static_cast<int>(copy.size()) > dimension_))
875 assert(std::is_sorted(copy.begin(), copy.end(), std::greater<Vertex_handle>()));
876 bool star = codimension == 0;
877 rec_coface(copy, &root_, 1, cofaces, star, codimension + static_cast<int>(copy.size()));
894 while (it1 != rg1.end() && it2 != rg2.end()) {
902 return ((it1 == rg1.end()) && (it2 != rg2.end()));
911 struct is_before_in_filtration {
917 if (sh1->second.filtration() != sh2->second.filtration()) {
918 return sh1->second.filtration() < sh2->second.filtration();
921 return st_->reverse_lexicographic_order(sh1, sh2);
946 template<
class OneSkeletonGraph>
951 if (boost::num_vertices(skel_graph) == 0) {
954 if (num_edges(skel_graph) == 0) {
960 root_.members_.reserve(boost::num_vertices(skel_graph));
962 typename boost::graph_traits<OneSkeletonGraph>::vertex_iterator v_it,
964 for (std::tie(v_it, v_it_end) = boost::vertices(skel_graph); v_it != v_it_end;
966 root_.members_.emplace_hint(
967 root_.members_.end(), *v_it,
968 Node(&root_, boost::get(vertex_filtration_t(), skel_graph, *v_it)));
970 typename boost::graph_traits<OneSkeletonGraph>::edge_iterator e_it,
972 for (std::tie(e_it, e_it_end) = boost::edges(skel_graph); e_it != e_it_end;
974 auto u = source(*e_it, skel_graph);
975 auto v = target(*e_it, skel_graph);
978 auto sh = find_vertex(u);
980 sh->second.assign_children(
new Siblings(&root_, sh->first));
983 sh->second.children()->members().emplace(
985 Node(sh->second.children(),
986 boost::get(edge_filtration_t(), skel_graph, *e_it)));
1003 dimension_ = max_dim;
1004 for (Dictionary_it root_it = root_.members_.begin();
1005 root_it != root_.members_.end(); ++root_it) {
1007 siblings_expansion(root_it->second.children(), max_dim - 1);
1010 dimension_ = max_dim - dimension_;
1015 void siblings_expansion(Siblings * siblings,
1017 if (dimension_ > k) {
1022 Dictionary_it next = siblings->members().begin();
1025 static std::vector<std::pair<Vertex_handle, Node> > inter;
1026 for (Dictionary_it s_h = siblings->members().begin();
1027 s_h != siblings->members().end(); ++s_h, ++next) {
1033 siblings->members().end(),
1034 root_sh->second.children()->members().begin(),
1035 root_sh->second.children()->members().end(),
1036 s_h->second.filtration());
1037 if (inter.size() != 0) {
1038 Siblings * new_sib =
new Siblings(siblings,
1042 s_h->second.assign_children(new_sib);
1043 siblings_expansion(new_sib, k - 1);
1046 s_h->second.assign_children(siblings);
1055 static void intersection(std::vector<std::pair<Vertex_handle, Node> >& intersection,
1056 Dictionary_it begin1, Dictionary_it end1,
1057 Dictionary_it begin2, Dictionary_it end2,
1058 Filtration_value filtration_) {
1059 if (begin1 == end1 || begin2 == end2)
1062 if (begin1->first == begin2->first) {
1063 Filtration_value filt = (std::max)({begin1->second.filtration(), begin2->second.filtration(), filtration_});
1064 intersection.emplace_back(begin1->first, Node(
nullptr, filt));
1065 if (++begin1 == end1 || ++begin2 == end2)
1067 }
else if (begin1->first < begin2->first) {
1068 if (++begin1 == end1)
1071 if (++begin2 == end2)
1089 os <<
key(b_sh) <<
1096 Vertex_handle null_vertex_;
1098 Filtration_value threshold_;
1103 std::vector<Simplex_handle> filtration_vect_;
1110 template<
typename...T>
1111 std::ostream& operator<<(std::ostream & os, Simplex_tree<T...> & st) {
1112 for (
auto sh : st.filtration_simplex_range()) {
1113 os << st.dimension(sh) <<
1114 for (
auto v : st.simplex_vertex_range(sh)) {
1117 os << st.filtration(sh) <<
"\n";
1122 template<
typename...T>
1123 std::istream& operator>>(std::istream & is, Simplex_tree<T...> & st) {
1124 typedef Simplex_tree<T...> ST;
1125 std::vector<typename ST::Vertex_handle> simplex;
1126 typename ST::Filtration_value fil;
1127 typename ST::Filtration_value max_fil = 0;
1129 while (read_simplex(is, simplex, fil)) {
1132 int dim =
static_cast<int> (simplex.size() - 1);
1133 if (max_dim < dim) {
1136 if (max_fil < fil) {
1140 st.insert_simplex(simplex, fil);
1143 st.set_dimension(max_dim);
1144 st.set_filtration(max_fil);
1152 #endif // SIMPLEX_TREE_H_
Simplex_tree_skeleton_simplex_iterator< Simplex_tree > Skeleton_simplex_iterator
Iterator over the simplices of the skeleton of the simplicial complex, for a given dimension...
Definition: Simplex_tree.h:215
unspecified Simplex_key
Key associated to each simplex.
Definition: FilteredComplex.h:35
Dictionary::iterator Simplex_handle
Handle type to a simplex contained in the simplicial complex represented by the simplex tree...
Definition: Simplex_tree.h:164
void expansion(int max_dim)
Expands the Simplex_tree containing only its one skeleton until dimension max_dim.
Definition: Simplex_tree.h:1002
Filtration_simplex_range::const_iterator Filtration_simplex_iterator
Iterator over the simplices of the simplicial complex, ordered by the filtration. ...
Definition: Simplex_tree.h:224
Simplex Tree data structure for representing simplicial complexes.
Definition: Simplex_tree.h:103
std::pair< Simplex_handle, bool > insert_simplex_and_subfaces(const InputVertexRange &Nsimplex, Filtration_value filtration=0)
Insert a N-simplex and all his subfaces, from a N-simplex represented by a range of Vertex_handles...
Definition: Simplex_tree.h:658
void assign_key(Simplex_handle sh, Simplex_key key)
Assign a value 'key' to the key of the simplex represented by the Simplex_handle 'sh'.
Definition: Simplex_tree.h:729
bool operator==(Simplex_tree &st2)
Checks if two simplex trees are equal.
Definition: Simplex_tree.h:388
Concept describing an indexing scheme (see FilteredComplex) for applying continuous maps to a cell co...
Definition: IndexingTag.h:30
static Simplex_key key(Simplex_handle sh)
Returns the key associated to a simplex.
Definition: Simplex_tree.h:426
static Simplex_handle null_simplex()
Returns a Simplex_handle different from all Simplex_handles associated to the simplices in the simpli...
Definition: Simplex_tree.h:461
boost::iterator_range< Complex_vertex_iterator > Complex_vertex_range
Range over the vertices of the simplicial complex.
Definition: Simplex_tree.h:190
Simplex_tree_simplex_vertex_iterator< Simplex_tree > Simplex_vertex_iterator
Iterator over the vertices of a simplex.
Definition: Simplex_tree.h:194
Vertex_handle null_vertex() const
Returns a Vertex_handle different from all Vertex_handles associated to the vertices of the simplicia...
Definition: Simplex_tree.h:473
void print_hasse(std::ostream &os)
Write the hasse diagram of the simplicial complex in os.
Definition: Simplex_tree.h:1084
Key type used as simplex identifier.
Definition: SimplexKey.h:27
Siblings * root()
Definition: Simplex_tree.h:752
bool has_children(Simplex_handle sh) const
Returns true iff the node in the simplex tree pointed by sh has children.
Definition: Simplex_tree.h:523
Simplex_tree(Simplex_tree &&old)
User-defined move constructor moves the whole tree structure.
Definition: Simplex_tree.h:355
unspecified Indexing_tag
Specifies the nature of the indexing scheme.
Definition: FilteredComplex.h:44
Filtration_value filtration() const
Returns an upper bound of the filtration values of the simplices.
Definition: Simplex_tree.h:453
Options::Simplex_key Simplex_key
Definition: Simplex_tree.h:114
bool operator!=(Simplex_tree &st2)
Checks if two simplex trees are different.
Definition: Simplex_tree.h:397
std::vector< Simplex_handle > Filtration_simplex_range
Range over the simplices of the simplicial complex, ordered by the filtration.
Definition: Simplex_tree.h:220
Boundary_simplex_range boundary_simplex_range(Simplex_handle sh)
Returns a range over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:310
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration...
Definition: Simplex_tree.h:277
void initialize_filtration()
Initializes the filtrations, i.e. sort the simplices according to their order in the filtration and i...
Definition: Simplex_tree.h:776
Simplex_handle find(const InputVertexRange &s)
Given a range of Vertex_handles, returns the Simplex_handle of the simplex in the simplicial complex ...
Definition: Simplex_tree.h:535
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:32
unspecified Boundary_simplex_range
Range giving access to the simplices in the boundary of a simplex.
Definition: FilteredComplex.h:85
Cofaces_simplex_range cofaces_simplex_range(const Simplex_handle simplex, int codimension)
Compute the cofaces of a n simplex.
Definition: Simplex_tree.h:865
Complex_simplex_range complex_simplex_range()
Returns a range over the simplices of the simplicial complex.
Definition: Simplex_tree.h:243
Filtration_simplex_range filtration_simplex_range()
Returns a range over the simplices of the complex in the order of the filtration. ...
Concept of the template parameter for the class Gudhi::Simplex_tree<SimplexTreeOptions>.
Definition: SimplexTreeOptions.h:27
std::pair< Simplex_handle, Simplex_handle > endpoints(Simplex_handle sh)
Definition: Simplex_tree.h:737
int dimension() const
Returns an upper bound on the dimension of the simplicial complex.
Definition: Simplex_tree.h:517
Complex_vertex_range complex_vertex_range()
Returns a range over the vertices of the simplicial complex. The order is increasing according to < o...
Definition: Simplex_tree.h:232
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh)
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:290
Options::Vertex_handle Vertex_handle
Type for the vertex handle.
Definition: Simplex_tree.h:118
unspecified Filtration_simplex_range
Range over the simplices of the complex in the order of the filtration.
Definition: FilteredComplex.h:110
Skeleton_simplex_range skeleton_simplex_range(int dim)
Returns a range over the simplices of the dim-skeleton of the simplicial complex. ...
Definition: Simplex_tree.h:257
boost::iterator_range< Boundary_simplex_iterator > Boundary_simplex_range
Range over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:204
void set_filtration(Filtration_value fil)
Definition: Simplex_tree.h:757
Cofaces_simplex_range star_simplex_range(const Simplex_handle simplex)
Compute the star of a n simplex.
Definition: Simplex_tree.h:854
void set_dimension(int dimension)
Definition: Simplex_tree.h:762
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:50
Siblings * self_siblings(Simplex_handle sh)
Definition: Simplex_tree.h:743
Simplex_handle simplex(Simplex_key key) const
Returns the simplex associated to a key.
Definition: Simplex_tree.h:435
int dimension(Simplex_handle sh)
Returns the dimension of a simplex.
Definition: Simplex_tree.h:506
static Simplex_key null_key()
Returns a key different for all keys associated to the simplices of the simplicial complex...
Definition: Simplex_tree.h:467
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:444
Handle type for the vertices of a cell complex.
Definition: VertexHandle.h:27
boost::transform_iterator< return_first, Dictionary_it > Complex_vertex_iterator
Iterator over the vertices of the simplicial complex.
Definition: Simplex_tree.h:188
~Simplex_tree()
Destructor; deallocates the whole tree structure.
Definition: Simplex_tree.h:367
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:478
If true, each simplex has extra storage for one Filtration_value, and this value is propagated by ope...
Definition: SimplexTreeOptions.h:39
size_t num_simplices()
returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:484
boost::iterator_range< Complex_simplex_iterator > Complex_simplex_range
Range over the simplices of the simplicial complex.
Definition: Simplex_tree.h:210
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:110
Simplex_tree()
Constructs an empty simplex tree.
Definition: Simplex_tree.h:320
Simplex_tree_boundary_simplex_iterator< Simplex_tree > Boundary_simplex_iterator
Iterator over the simplices of the boundary of a simplex.
Definition: Simplex_tree.h:202
boost::iterator_range< Skeleton_simplex_iterator > Skeleton_simplex_range
Range over the simplices of the skeleton of the simplicial complex, for a given dimension.
Definition: Simplex_tree.h:218
Simplex_tree_complex_simplex_iterator< Simplex_tree > Complex_simplex_iterator
Iterator over the simplices of the simplicial complex.
Definition: Simplex_tree.h:208
void insert_graph(const OneSkeletonGraph &skel_graph)
Inserts a 1-skeleton in an empty Simplex_tree.
Definition: Simplex_tree.h:947
unspecified Filtration_value
Definition: FilteredComplex.h:39
Simplex_tree(const Simplex_tree &simplex_source)
User-defined copy constructor reproduces the whole tree structure.
Definition: Simplex_tree.h:328
boost::iterator_range< Simplex_vertex_iterator > Simplex_vertex_range
Range over the vertices of a simplex.
Definition: Simplex_tree.h:196
std::pair< Simplex_handle, bool > insert_simplex(const InputVertexRange &simplex, Filtration_value filtration=0)
Insert a simplex, represented by a range of Vertex_handles, in the simplicial complex.
Definition: Simplex_tree.h:629
depth first search, inserts simplices when reaching a leaf.
Definition: Simplex_tree.h:340
std::vector< Simplex_handle > Cofaces_simplex_range
Range over the cofaces of a simplex.
Definition: Simplex_tree.h:198
