Gudhi  1.2.0
 All Classes Functions Variables Typedefs Friends Groups Pages
FilteredComplex.h
1  /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): Clément Maria
6  *
7  * Copyright (C) 2014 INRIA Sophia Antipolis-Méditerranée (France)
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22
29 {
31  typedef unspecified Simplex_handle;
35  typedef unspecified Simplex_key;
39  typedef unspecified Filtration_value;
40
44  typedef unspecified Indexing_tag;
45
52  size_t num_simplices();
54  int dimension(Simplex_handle sh);
60
73
79 typedef unspecified Boundary_simplex_iterator;
85 typedef unspecified Boundary_simplex_range;
86
99
105 typedef unspecified Filtration_simplex_iterator;
110 typedef unspecified Filtration_simplex_range;
116
117
118 /* \brief Iterator over the simplices of the complex,
119  * in an arbitrary order.
120  *
121  * 'value_type' must be 'Simplex_handle'.*/
122 //typedef unspecified Complex_simplex_iterator;
123 //typedef unspecified Complex_simplex_range;
124
125 /*
126 * Returns a range over all the simplices of a
127 * complex.
128 */
129 //Complex_simplex_range complex_simplex_range();
130
131 /*************************************************/
140 //int is_before_in_filtration(Simplex_handle s, Simplex_handle t);
141 /*************************************************/
142
143 };
Iterator on the simplices belonging to the boundary of a simplex.
Definition: FilteredComplex.h:79
Key associated to each simplex.
Definition: FilteredComplex.h:35
void assign_key(Simplex_handle sh, Simplex_key key)
Assign a key to a simplex.
Simplex_key null_key()
Returns a key that is different from the keys associated to the simplices.
Simplex_key key(Simplex_handle sh)
Returns the key associated to a simplex.
Specifies the nature of the indexing scheme.
Definition: FilteredComplex.h:44
Iterator over all simplices of the complex in the order of the indexing scheme.
Definition: FilteredComplex.h:105
Simplex_handle null_simplex()
Range giving access to the simplices in the boundary of a simplex.
Definition: FilteredComplex.h:85
Filtration_simplex_range filtration_simplex_range()
Returns a range over the simplices of the complex in the order of the filtration. ...
Returns the number of simplices in the complex.
Definition: FilteredComplex.h:31
Range over the simplices of the complex in the order of the filtration.
Definition: FilteredComplex.h:110
Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Returns the dimension of a simplex.
Simplex_handle simplex(Simplex_key key)
Returns the simplex associated to a key.
The concept FilteredComplex describes the requirements for a type to implement a filtered cell comple...
Definition: FilteredComplex.h:28
Type for the value of the filtration function.
Definition: FilteredComplex.h:39
Boundary_simplex_range boundary_simplex_range(Simplex_handle sh)
Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimens...
