Gudhi  1.2.0
 All Classes Functions Variables Typedefs Friends Groups Pages
Contraction_visitor.h
1 /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): David Salinas
6  *
7  * Copyright (C) 2014 INRIA Sophia Antipolis-Mediterranee (France)
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22
23 #ifndef CONTRACTION_POLICIES_CONTRACTION_VISITOR_H_
24 #define CONTRACTION_POLICIES_CONTRACTION_VISITOR_H_
25
26 #include <gudhi/Contraction/Edge_profile.h>
27 #include <boost/optional.hpp>
28
29 namespace Gudhi {
30
31 namespace contraction {
32
38 template <typename EdgeProfile>
39 class Contraction_visitor { // : public Dummy_complex_visitor<typename EdgeProfile::Vertex_handle> {
40  public:
41  // typedef typename ComplexType::GeometryTrait GT;
42  typedef EdgeProfile Profile;
43  typedef double FT;
44  typedef typename Profile::Complex Complex;
45  typedef Complex ComplexType;
46  typedef typename ComplexType::Point Point;
47
48  virtual ~Contraction_visitor() { }
49
53  virtual void on_started(ComplexType & complex) { }
54
58  virtual void on_stop_condition_reached() { }
59
63  virtual void on_collected(const Profile &profile, boost::optional< FT > cost) { }
64
68  virtual void on_selected(const Profile &profile, boost::optional< FT > cost, int initial_count, int current_count) { }
69
73  virtual void on_contracting(const Profile &profile, boost::optional< Point > placement) { }
74
79  virtual void on_contracted(const Profile &profile, boost::optional< Point > placement) { }
80
84  virtual void on_non_valid(const Profile &profile) { }
85 };
86
87 } // namespace contraction
88
89 } // namespace Gudhi
90
91 #endif // CONTRACTION_POLICIES_CONTRACTION_VISITOR_H_
Called when an edge is about to be contracted and replaced by a vertex whose position is *placement...
Definition: Contraction_visitor.h:73
Called during the collecting phase (when a cost is assigned to the edges), for each edge collected...
Definition: Contraction_visitor.h:63
virtual void on_started(ComplexType &complex)
Called before the edge contraction process starts.
Definition: Contraction_visitor.h:53
Interface for a visitor of the edge contraction process.
Definition: Contraction_visitor.h:39
Called for each selected edge which cannot be contracted because the ValidContractionPredicate is fal...
Definition: Contraction_visitor.h:84
Called when the algorithm stops.
Definition: Contraction_visitor.h:58
Called during the processing phase (when edges are contracted), for each edge that is selected...
Definition: Contraction_visitor.h:68
Called when after an edge has been contracted onto a new point placement. A possibility would to remo...
Definition: Contraction_visitor.h:79
