Gudhi  1.1.0
 All Classes Functions Typedefs Friends Groups Pages
Skeleton_blocker_complex_visitor.h
1  /* This file is part of the Gudhi Library. The Gudhi library
2  * (Geometric Understanding in Higher Dimensions) is a generic C++
3  * library for computational topology.
4  *
5  * Author(s): David Salinas
6  *
7  * Copyright (C) 2014 INRIA Sophia Antipolis-Mediterranee (France)
8  *
9  * This program is free software: you can redistribute it and/or modify
10  * it under the terms of the GNU General Public License as published by
11  * the Free Software Foundation, either version 3 of the License, or
12  * (at your option) any later version.
13  *
14  * This program is distributed in the hope that it will be useful,
15  * but WITHOUT ANY WARRANTY; without even the implied warranty of
16  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
17  * GNU General Public License for more details.
18  *
19  * You should have received a copy of the GNU General Public License
20  * along with this program. If not, see <http://www.gnu.org/licenses/>.
21  */
22 #ifndef GUDHI_COMPLEXVISITOR_H_
23 #define GUDHI_COMPLEXVISITOR_H_
24
25
26 #include "gudhi/Skeleton_blocker/Skeleton_blocker_simplex.h"
27
28 namespace Gudhi{
29
30 namespace skbl {
31 // todo rajouter les const
32
37 template <typename Vertex_handle>
39 public:
41
42  virtual void on_add_vertex(Vertex_handle) = 0;
43  virtual void on_remove_vertex(Vertex_handle) = 0;
44
45  virtual void on_add_edge(Vertex_handle a,Vertex_handle b) = 0;
46  virtual void on_remove_edge(Vertex_handle a,Vertex_handle b) = 0;
47
52  virtual void on_changed_edge(Vertex_handle a,Vertex_handle b) = 0;
53
62  virtual void on_swaped_edge(Vertex_handle a,Vertex_handle b,Vertex_handle x)=0;
63  virtual void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>&) = 0;
64  virtual void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>*) = 0;
65 };
66
67
73 template <typename Vertex_handle>
75 public:
76  void on_add_vertex(Vertex_handle) {}
77  void on_remove_vertex(Vertex_handle){}
78  void on_add_edge(Vertex_handle a,Vertex_handle b){}
79  void on_remove_edge(Vertex_handle a,Vertex_handle b){}
80  void on_changed_edge(Vertex_handle a,Vertex_handle b){}
81  void on_swaped_edge(Vertex_handle a,Vertex_handle b,Vertex_handle x){}
82  void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>&){}
83  void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>*){}
84
85 };
86
87
88
94 template <typename Vertex_handle>
96 public:
97  void on_add_vertex(Vertex_handle v) {
98  std::cerr << "on_add_vertex:"<<v<<std::endl;
99  }
100  void on_remove_vertex(Vertex_handle v){
101  std::cerr << "on_remove_vertex:"<<v<<std::endl;
102  }
103  void on_add_edge(Vertex_handle a,Vertex_handle b){
104  std::cerr << "on_add_edge:"<<a<<","<<b<<std::endl;
105  }
106  void on_remove_edge(Vertex_handle a,Vertex_handle b){
107  std::cerr << "on_remove_edge:"<<a<<","<<b<<std::endl;
108  }
109  void on_changed_edge(Vertex_handle a,Vertex_handle b){
110  std::cerr << "on_changed_edge:"<<a<<","<<b<<std::endl;
111  }
112  void on_swaped_edge(Vertex_handle a,Vertex_handle b,Vertex_handle x){
113  std::cerr << "on_swaped_edge:"<<a<<","<<b<<","<<x<<std::endl;
114  }
115  void on_add_blocker(const Skeleton_blocker_simplex<Vertex_handle>& b){
116  std::cerr << "on_add_blocker:"<<b<<std::endl;
117  }
118  void on_delete_blocker(const Skeleton_blocker_simplex<Vertex_handle>* b){
119  std::cerr << "on_delete_blocker:"<<b<<std::endl;
120  }
121 };
122
123 }
124
125 } // namespace GUDHI
126
127 #endif /* GUDHI_COMPLEXVISITOR_H_ */
virtual void on_swaped_edge(Vertex_handle a, Vertex_handle b, Vertex_handle x)=0
Called when performing an edge contraction when an edge bx is replaced by an edge ax (not already pre...
void on_changed_edge(Vertex_handle a, Vertex_handle b)
Called when an edge changes, during the contraction of an edge.
Definition: Skeleton_blocker_complex_visitor.h:80
A visitor that prints the visit information.
Definition: Skeleton_blocker_complex_visitor.h:95
A dummy visitor of a simplicial complex that does nothing.
Definition: Skeleton_blocker_complex_visitor.h:74
Definition: Skeleton_blocker_complex_visitor.h:81
virtual void on_changed_edge(Vertex_handle a, Vertex_handle b)=0
Abstract simplex used in Skeleton blockers data-structure.
Definition: Skeleton_blocker_simplex.h:48
Interface for a visitor of a simplicial complex.
Definition: Skeleton_blocker_complex_visitor.h:38
Definition: Skeleton_blocker_complex_visitor.h:112
Definition: Skeleton_blocker_complex_visitor.h:109
