23 #ifndef SRC_PERSISTENT_COHOMOLOGY_INCLUDE_GUDHI_PERSISTENT_COHOMOLOGY_MULTI_FIELD_H_
24 #define SRC_PERSISTENT_COHOMOLOGY_INCLUDE_GUDHI_PERSISTENT_COHOMOLOGY_MULTI_FIELD_H_
33 namespace persistent_cohomology {
45 typedef mpz_class Element;
48 : prod_characteristics_(0),
55 void init(uint16_t min_prime, uint16_t max_prime) {
57 std::cerr <<
"There is no prime less than " << max_prime << std::endl;
59 if (min_prime > max_prime) {
60 std::cerr <<
"No prime in [" << min_prime <<
":" << max_prime <<
64 uint16_t curr_prime = min_prime;
66 mpz_init_set_ui(tmp_prime, min_prime);
68 int is_prime = mpz_probab_prime_p(tmp_prime, 25);
71 mpz_nextprime(tmp_prime, tmp_prime);
72 curr_prime = mpz_get_ui(tmp_prime);
75 while (curr_prime <= max_prime) {
76 primes_.push_back(curr_prime);
77 mpz_nextprime(tmp_prime, tmp_prime);
78 curr_prime = mpz_get_ui(tmp_prime);
81 prod_characteristics_ = 1;
82 for (
auto p : primes_) {
83 mpz_mul_ui(prod_characteristics_.get_mpz_t(),
84 prod_characteristics_.get_mpz_t(), p);
90 for (
auto p : primes_) {
92 tmp_elem = prod_characteristics_ / p;
94 mpz_powm_ui(tmp_elem.get_mpz_t(), tmp_elem.get_mpz_t(), p - 1,
95 prod_characteristics_.get_mpz_t());
96 Uvect_.push_back(tmp_elem);
99 for (
auto uvect : Uvect_) {
100 assert(prod_characteristics_ != 0);
101 mult_id_all = (mult_id_all + uvect) % prod_characteristics_;
105 void clear_coefficient(Element & x) {
106 mpz_clear(x.get_mpz_t());
119 if (Q == prod_characteristics_) {
123 assert(prod_characteristics_ != 0);
125 for (
unsigned int idx = 0; idx < primes_.size(); ++idx) {
126 assert(primes_[idx] != 0);
127 if ((Q % primes_[idx]) == 0) {
128 mult_id = (mult_id + Uvect_[idx]) % prod_characteristics_;
135 Element
times(
const Element& y,
const Element& w) {
139 Element plus_equal(
const Element& x,
const Element& y) {
145 return prod_characteristics_;
149 std::pair<Element, Element>
inverse(Element x, Element QS) {
151 mpz_gcd(QR.get_mpz_t(), x.get_mpz_t(), QS.get_mpz_t());
154 Element QT = QS / QR;
156 mpz_invert(inv_qt.get_mpz_t(), x.get_mpz_t(), QT.get_mpz_t());
158 assert(prod_characteristics_ != 0);
159 return std::pair<Element, Element>(
164 assert(prod_characteristics_ != 0);
165 return prod_characteristics_ - ((x * y) % prod_characteristics_);
170 assert(prod_characteristics_ != 0);
171 Element result = (x + w * y) % prod_characteristics_;
173 result += prod_characteristics_;
177 Element prod_characteristics_;
179 std::vector<uint16_t> primes_;
180 std::vector<Element> Uvect_;
182 const Element add_id_all;
189 #endif // SRC_PERSISTENT_COHOMOLOGY_INCLUDE_GUDHI_PERSISTENT_COHOMOLOGY_MULTI_FIELD_H_
const Element & multiplicative_identity() const
Returns the multiplicative identity of the field.
Definition: Multi_field.h:114
const Element & characteristic() const
Returns the characteristic of the field.
Definition: Multi_field.h:144
std::pair< Element, Element > inverse(Element x, Element QS)
Definition: Multi_field.h:149
Element times(const Element &y, const Element &w)
Definition: Multi_field.h:135
Element times_minus(const Element &x, const Element &y)
Definition: Multi_field.h:163
const Element & additive_identity() const
Returns the additive idendity of the field.
Definition: Multi_field.h:110
Structure representing coefficients in a set of finite fields simultaneously using the chinese remain...
Definition: Multi_field.h:43
Element plus_times_equal(const Element &x, const Element &y, const Element &w)
Definition: Multi_field.h:169
